how can i communicate with the 46c n2o analyzer from thermo ei?
I have problems with the communication with the TEI 46C N2O analyzer. It doesn't respond, although I did as described in the manual. Had anyone had a similar problem?
(3,651 Views)
I need more infos to solve the problem, is it possible to isolate the problem a little? I think you use a GPIB Interface, if this is right, which do you use? Have you installed the current driver? Do you get an error message?
Regards
Thomas D.
NI Germany
(SRQ 199564)
(3,651 Views)
Hello ThomasD
I have found a LabView Driver for this instrument, so the communication works now (RS232 interface).
Thanks anyway
(3,651 Views)
Hello
I am trying to communicate  42C NOx Analyzer with the labview but i couldn't it's showing error message. if anyone knows how to communicate C series NOx Analyzer please help me.
(3,161 Views)
How can anyone help if you don't provide the error message (and exact code) that yu are getting?
(3,157 Views)
