how can i get a 3d plotting using data uploaded to a laptop through a usb port with x,y, z coordinates
Hi,  I'm new to labview.  I have a project to finish up in my robotic class.  I've built a robot to go through a tunnel equipped with a servo motor attached to a IR sensor.  The robot scans the tunnel get the distance reading in x,y,z coordinates and sends those data to my laptop.  I have successfully display the reading using hyperterminal, but the new task is to use those data to plot a 3d image of the tunnel in real time.   I don't know how to take those data being uploaded from the robot through a usb and making a 3d plot of the tunnel in real time in labview.  Can someone please help.
thanks in advance.
LCD
(3,182 Views)
The data will have to transfered from your robot to a PC using VISA.
VISA gives you ability to communicate with your USB compliance device.
You will have to read over the following articles
1. How can I communicate with a device using USB Raw
2. USB Instrument Control
These article along with the example programs that come with LabVIEW and NI VISA
will get you started.
Christian A
(3,159 Views)
