how can i verify the CD serial line?
I need to detect the signal connection with a modem. how can I access to the carrier detect line?
(3,064 Views)
Hello Lucia,
Assuming that you are using LabVIEW, you can follow the steps in the Knowledge Base below. You will need NI-VISA, which you can download from our website if you do not already have it installed.
Can LabVIEW Test if My Modem Is Connected?
VISA Download Webpage
Mike N.
(3,064 Views)
