how firmware VISA basedcan pay advantage of fast data streaming of PCIe/PXIe plaform
Hi
    I know this white paper! this is not the first driver that I write. The precedents was for PLX9030. This was a more simple works because in PCI/PXI bridge without DMA or other possibilities and then with moveInXX and moveOutxx was suffisant...(with openSession and close!)
 But this time is with PEX8311 and it is more complicated!
I receive from PLX a SDK and I need to study his driver to sucess to write a NI VISA driver. To explain to wizard how to work I need to understand better the chip and as perhaps I should have the good questions to ask....
Thanks for your help
Dina
Message 11 of 16
(1,446 Views)
Hello!
Do you have any success ?
I'm working on the same field but I couldn't get high-speed transfer until now.
I created driver as mentioned in http://www.ni.com/white-paper/4713/en white-paper.
But this white-paper has no information about DMA.
So I can get 20Mbytes/s for write-transfer and 2Mbyte/s for read-transfer.
(viMoveInxx/viMoveOutxx functions and Peek/Poke on mapped region gives almost the same results.)
All transfers has 1DW length (simple PIO interface).
Screenshots of pcie transactions on TLP level are included.
I marked SOF/EOF and time stamp (1clk = 16ns).
This is definitely not DMA(
Also I tried set attribute "Allow DMA transfer" but got an error "is not defined or supported".
Waiting for the help!
Message 12 of 16
(1,425 Views)
I am not sure that the scope of the VISA driver development wizard allows us to configure DMA access.
Have either of you looked into using the NI Measurement Hardware DDK (Driver Development Kit)?
http://sine.ni.com/nips/cds/view/p/lang/en/nid/11737
This gives us register level programming examples to control DMA functions on NI and possibly third-party hardware.
http://digital.ni.com/public.nsf/allkb/1C3988D7D33B925C86256C59007FB4B4?OpenDocument
It may also be worth checking out the Driver Development Kit forum:
http://forums.ni.com/t5/Driver-Development-Kit-DDK/bd-p/90
Joey S.
Senior Product Manager, Software
Message 13 of 16
(1,410 Views)
Hi
   I use the DDK is a great idea! I success to work with DMA. I do not test performance already ( I work with an evaluation board now) but this is suffisant for a first try!
Dina
Message 14 of 16
(1,395 Views)
Hello!
J_spin, thanks!
I will look into this direction (DDK).
Firmware_programmer, could you please share your DMA solution (or maybe just briefly description of performed steps)?
Are there any "hidden dangers" ?
thanks a lot!
Message 15 of 16
(1,391 Views)
HI
I attached my first try. I is a single DMA transfer. This week I will continue... Check Burst possibilities, and Scatters/gathred mode...
Good luck
Dina
Message 16 of 16
(1,384 Views)
