how long it takes for a kistler 9255B to give an output for drilling a hole
how long it takes for a kistler 9255B dyno to give an output readings for cutting forces and moment when drilling a hole in a 10 mm plate .
(4,276 Views)
Kistler is not an NI product.
(4,268 Views)
The 9255B is just the piezo sensor with it's resonance at about 3kHz (depending of mass load, see it as a SDOF system)
The complex transferfunction (up to fg) should be noted in calibration sheet. If not ask Kistler.
What are you using to read the charge?
Usually charge amplifier have a group delay in or below tenth of µs....
Greetings from Germany
Henrik
LV since v3.1
(4,211 Views)
