how to display X-Y graph from 1D array?
I have VI which communicates with instrument and aquires data ( 1D array ) ie. (-1,0),(0,0),(1,1),(2,3),(3,8),(4,25) These are just sample values which I'm getting.
I want to display these values on the X-Y graph where X is the 1st element of the array and Y is the second. Perhaps it is very simple, unfortunatelly I cannot find way to do it.
(3,053 Views)
You say it's a 1D array but the way you are defining the data, it's a 2D array. If you are getting two samples and are creating a 1D array from them, then you should be creating a 2D array. Once you have a 2D array, then you can use the index array function to get either the row or column and then bundle them together to create the input that an XY graph requires.
(3,050 Views)
