how to log data??
How to log data of waveform graph that includes amplitude,frequency,peak to paek voltage in the interval of 1 minute with exp no. and date and time to displayed only once.
Also a button to initiate data logging when requires to ask.
This is to be done without using labview signal express or any other software......only labview software should be use for programmming.
Message Edited by Dreamliner on 03-08-2010 11:56 PM
(3,363 Views)
use build array for the signals, eventually transpose this data, feed it to write to spreadsheetfile and make sure that append to file is true.
greetings from the Netherlands
(3,355 Views)
