how to pass visa resource name from one vi to other vi
i want to pass visa resource name from one vi to other vi through tcl .i am able to obtain the visa resource name from initialise.vi to tcl , it returns something like "dmm 1099384" no when  i pass this to my other subvi  it  gives error like "paramnames type mismatch.expected 1d array of strings or 1d array of string variants". Below is the code that i am using
package require tcom
# close Tk widnow
catch {wm withdraw .}
# open LabVIEW application
set lview [::tcom::ref createobject "LabView.Application"]
set path "C:\\Documents and Settings\\rajr1\\Desktop\\project\\dmm\\initialise.vi"
set vi [$lview GetVIReference $path]
$vi Run
set seid [$vi GetControlValue "VISA resource name out"]
set path "C:\\Documents and Settings\\rajr1\\Desktop\\project\\dmm\\singlemeasurement module.vi"
set names [list "Measurement Data" "VISA resource name"]
set values [list 2 $seid]
$vi Call names values
puts [lindex $values 0]
$lview Quit
(3,870 Views)
help please 😞
(3,855 Views)
Why not use a string
greetings from the Netherlands
(3,841 Views)
Hey P1,
A useful tool to use to troubleshoot would be NI-SPY. It shows the driver level calls being made, and you should be able to see what resource it's trying to use. If you would like, it'd be good to also try to put indicators in your program to show what's actually being used.
Like mentioned above, would you be able to pass the information as a string, and try to implement it that way?
Nick D.
(3,825 Views)
One last thing...
You can find NI-SPY at Start->Programs->National Instruments->NI-SPY.
Nick D
(3,822 Views)
