how to run a Masterflex L/S 7523-90 pump with a USB 6009
Hello and thank you for viewing my post. I'm setting up an automated filtration system in my lab. The first instrument I need to interface with is a Masterflex pump.
The only connection to this pump is a DB-25. I've attached a picture of the pinout given in the manual.
The only functionality I need is on/off and speed control. It seemed like a straight forward task at first but I cant figure out what kind of signal to send to the remote start/stop input with the USB 6009. Can anyone offer some advise?
(5,313 Views)
Since they don't spec a voltage I have a hunch it is looking for a contact closure that connects pin 15 to 17. You may want to 'contact' the manufacturer to verify.
If so, you would need one of the 6008's digital outputs to control a relay. Since it does not have enough current drive to do so directly, you would need a transistor or drive chip between the 6008 output and the relay coil.
-AK2DM
(5,294 Views)
I want to run the Masterflex 7521-55 pump with NI USB 6008, is it possible? Could anyone let me know how to do this?
Wendy
(4,954 Views)
Hi Wendy,
This thread is fairly old, the orignal authors may not be following it anymore. I would recommend making a new post with your question. I wasn't able to find the Masterflex 7521-55 on their website, so I have no idea how you would use a USB DAQ device to control it. Could you include more information, possibly the data sheet, connection method, etc., in your new post?
Ian K.
Software Developer
Data Ahead AG
(4,932 Views)
Dear Ian,
Many thanks for your reply.
I have tested the pump with a variable voltage power supply, the speed can be controlled by providing 4 - 20 mA, and a 5V for stop/start.
We have USB6008, if we can get a variable voltage output (2 to 5 V), the speed can be changed from low to high.
Please see attached pics for the pump's info..
I am looking forward to hearing from you.
Kind regards
Wendy
(4,923 Views)
Wendy,
If I read your previous post correctly, the pins that control the speed of the pump require a minimum of 4 mA. If that's true, you could use one of your analog outputs on the 6008 to control the speed of you pump by varying it between 2 and 5V.  You need to be careful though, the 6008 has a maximum current drive of 5 mA. If the pins require a higher current to control the speed of the pump, you won't be able to use the 6008.
Also, feel free to take a look at the user manual to see if the 6008 meets the specifications required for your application.
Ian K.
Software Developer
Data Ahead AG
(4,913 Views)
Dear Ian,
Thanks for your reply, the pump needs 4 - 20 mA for changing the speed from low to high. I will check the 6008's specification for the current limit and whether it has the counter function for timing control as well.
Kind regards
Wendy
(4,904 Views)
