how to send data into parallel data port by visa interface?
HI, all,
i want to send data to parallel data port by visa interface. I get a example vi from
ni webpage. But it seem that it cannot work. Becuse when i set a value. read value
by other tool, nothing is set.  Can you tell me ho to uset it?
http://sine.ni.com/devzone/cda/epd/p/id/4213
I attached that example too.
Thanks.
(3,645 Views)
Can you tell me more details how you verify the data you have sent?
what is the instruments that you are communicating to?
NI AE Yang Liu
(3,626 Views)
hi peter_liu
After  set, i can use Parallel_Debug.exe to read data register, but no change.
For labview example proram:Parallel Port Read and Write Loop.vi, it has the same result.
So i don't know how to set data register by visa interface. I mean if i use Parallel Port Read and Write Loop.vi
or Parallel_Debug.exe  to set data, it can work.
I try to communcate with a test board, it need command to open switch on it.
thanks.
(3,622 Views)
