how to send labview data to one of the usb ports of the system..?
i have a tracker data ie;roll, pitch and yaw data in the labview.. i need to send this data to one of the usb ports of the computer to control servo motors using parallax usb servo controller board.. aim of the project is to move two servo motors according to the head movements.. head movements are tracked using intersense itrax2 sensor.. plz help..
(2,885 Views)
So you need a driver for the motion control and all you need to do is call this driver with the data you need.
The USB port is part of the motion control driver probably.
greetings from the Netherlands
(2,883 Views)
