how to synchronize SERIAL PORT and USB-6229
do i require any additional hardware to get this sync done between serial port(usb-serial port) and usb-6229?
Now on LabVIEW 10.0 on Win7
Message 1 of 16
(5,486 Views)
what do you want to synchronise?
what is coming from serial, what is coming from usb?
what time resolution do you need (seconds or microseconds)?
greetings from the Netherlands
Message 2 of 16
(5,482 Views)
i would like to save data from DAQmx from USB-6229 and some serial data(volts) from usb-serial converter(com port basically) into 1 file. the serial data is coming at 9600 baud(fixed).
i wuld like to save this data in hh:mm:ss.x format.
Message 3 of 16
(5,478 Views)
You did not answer how accurate your synchronisation needs to be
Message 4 of 16
(5,471 Views)
i did not understand what do you mean by how accurate?i would like to save every sample being collected, does it answer your question?
Message 5 of 16
(5,469 Views)
So we know you have a USB 6229...
so, whats on the rs232? a $20 cheapo DMM with a 1S/s output or Agilent ??? with serial out and soft/hard-trigger??
What do you mean by synchronize?
If you record every second will a mismatch of +-1s between the capture times of the different instruments hurt?
How do you collect the data frm the 6229? Do you use triggers?
Without a hardware sync you have to count with a random mismatch due to the OS .. coarse guess 20ms but will that matter?
Greetings from Germany
Henrik
LV since v3.1
Message 6 of 16
(5,453 Views)
--- i have voltage signal coming from USB-SERIAL convertor, i dunt know what is the input to that USB-SERIAL converter.. is it another DAQ, or an electronic circuit dunno...
-- by synchronize, i mean that when i save the data coming from two DAQ systems, they should be stored in a file without any loss of data. Since the clock on these 2 DAQs are independent, and of different values, there is a possibility that 1 DAQ has some data at a given instance, while other DAQ does not (just because their clocks and rate of acquisiton is different), so, i would like my system to either coerce or have a common clock base, so that I can cut out this problem.
Yes,,, it will because in that case, I will have 100% error? Will I or I am wrong?
No, I have generated a simple task using the internal clocks of the CPU. no triggers nothing.. i used Daqmx Start Task.vi
 i have no clue about it... did not try yet
Message 7 of 16
(5,432 Views)
When you find out what make and model of instrument is going to be used, post back. Otherwise, speculating is just a complete waste of time.
Message 8 of 16
(5,426 Views)
Maybe he can help: 😉
Henrik
LV since v3.1
Message 9 of 16
(5,413 Views)
hello all,
           i found out something on the hardware from which the serial data is coming in... its basically a DAQ box which would simulate the DAQ boxes from NI. it is built up of all board level electronics, Filters, Amplifiers, micro-processor, etc... i found that the max baud rate is 115k on that electronics box....
does this help?
Message 10 of 16
(5,388 Views)
