how to toogle between channels
I need feed the same data in a loop into DO lines. These lines should change between two sets of lines from iteration to itetation (you may think there is only two lines to toogle between) i.e. on the first interation the data are fed into first line, then into second, then again into first e.t.c.
What is the most concise way to accoplish this? I'm using DAQmx.
(2,978 Views)
duplicate of here
Justin Parker
Product Support Engineer
(2,963 Views)
