how to use IVI driver in CVI
hello to every one,
My question is how can i use IVI driver for Tektronix 2014B oscilloscope in Labwindows?
i am using this oscilloscope to analyse the CAN signal. now i want create a DLL  to read this scope and  to do the  following functions like Configuring,acquire signal from scope&  analyse it.
suggest me some ideas,because i am very new to this Intrument drivers Topic.
thank you
(3,352 Views)
If you haven't already, you should first download an IVI-C driver for your instrument from ni.com/idnet:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E94FE659CE034080020E748...
Each IVI driver includes an example (tktds1k2k_example.c) which you should try to use. The example can be a good starting point for developing your application.
(3,331 Views)
(3,316 Views)
