how to use labview as virtual printer by parallel port?
hi guys, I try to use labview to read the info of a tester equipment (cirris 1100R+), this equipment send to print a report by parallel port with protocol ascii centronics, i want to read this info with the pc and decodify to show it in a vi, i try to read the port LPT1, using VISA driver without result, I also try with IO port DLL with the same result, i follow the next literature:
link: http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB
(5,043 Views)
Use a sile digital 8 bit input card, prefrebly with two control lines out and 1 input extra for handshaking.
A usb 5001 should be enoigh, maybe to little handshake.
greetings from the Netherlands
(5,025 Views)
Long long time ago I had a similar task and used a parallel to serial converter .......
However it was possible to read the LPT port .... but I think it's getting harder with the modern OS versions....    I remember also some BIOS settings that needed to changed.
Greetings from Germany
Henrik
LV since v3.1
(4,956 Views)
just for curiosity what's mean SILE?
(3,620 Views)
a simple typing error.... I missed two characters
(3,612 Views)
