how to write Modbus data in a file or array??
Hi:
I can monitor my required data via RS-485 port using "MB serial Master query", and I can successfully show the signals using waveform chart.
But I can not save data during the test in an array or write them in a file!!!(see attached file and picture)
How can i write them in a file or spreadsheet correctly??
when i try to read data from "measurement file" and graph it, I can not get any graph, it just have a node!!!
is the "input registers" data type needs a special procedure?
what's the problem??
Thanks.
(5,532 Views)
Accepted by topic author jftak01
One basic mistake I see is that you have the Write to Measurement File configured to rename and overwrite any existing file when you call the function.
(5,526 Views)
Thanks dennis:
You mean I have to select "append to existing file" in measurement file configuration??
what about the writing in array format problem?? I mean when the program is running and reading "input registers", I expect to see them in an array format in front panel (see Pic attached). but only the first component of array is changing alaways, and other components are always 0?
I expect to see each number in each component of array?
how can i do that?
thanks.
(5,521 Views)
No. The other elements are NOT zero. The other elements in the array are empty. Are there other registers to be read? Your other read with a different starting address is empty.
(5,510 Views)
yes. there are , but the thing is. I want to have different values of just one register during the time in an array format( I man a specific numer in each of the array elements).. is it posiible?? I think i can not see this form in front panel.. I must write data in a measrement file.  am i right?
I think now it's rewriting just the first element of array.
thanks
(5,502 Views)
To keep an array of the single element with a value, use the Index Array to get element 0 and then a shift register with a Build Array function where you pass it the current element.
(5,496 Views)
I used MODBUS.
Now, it works well.
Thank you all.
Jafar
(5,456 Views)
