how to write gpib's 4882 regester ?
Clover,
Let me know if you have any additional questions.
Steven T.
Message 11 of 18
(2,083 Views)
Hello Steven T,
If the NI-488DDK 1.1 could use for  TNT5002 pci-gpib?
Message 12 of 18
(2,062 Views)
Hello all,
      If the NI-488DDK 1.1 source code could be used for TNT5002 pci-gpib?
I found it can be used in the TNT4882 pci-gpib developing,but the regesters between tnt4882 and tnt5002 different.
Thank you!
clover
Message 13 of 18
(2,048 Views)
Hello clover,
The NI-488.2 DDK allows you to work with a PCI-GPIB board from National Instruments.  These boards are controllers, so they can talk/listen/control the bus.
The important distinction here is that the PCI-GPIB does not come with a TNT5002.  It comes with a TNT5004, which is a different chip.  Please comment on what you are using.  In all of your posts, you mention both the PCI-GPIB as well as the TNT5002.
Steven T.
Message 14 of 18
(2,040 Views)
Hello Steven T,
First,thank your help for so long time!I drived the pci-gpib board based on tnt5002 with the datasheet and your help,now,it can transfer data which less than 32 bytes with usb-gpib on the  pc.I am not use the NI-488DDK... .But I still have a problem,I don't known how to response to controller's *IDN? command.Need I receive the string "*IDN?" and use the sending code to response ?
Thank you very much!
Clover.
Message 15 of 18
(1,962 Views)
Hello Steven T,
With the last post,I read BSR,the value is 0x30,and datasheet said "TNT5002 can't assert ATN#,IFC#,or REN#",I know it's mean that tnt5002 is not a controller.
Message 16 of 18
(1,955 Views)
Steven T,
I believe myself much more.It will be software first receive the 488 command such as *IDN?,RST,*OPC? and response to controller for it.Because anything else,data or command,which will write to GFIFO.The tnt5002 doesn't known the differ between data and the command.
Is it right?
Thank you!
clover.
Message 17 of 18
(1,953 Views)
Hello all,
Please help me,I think this is the last question.
Thank you!
Message 18 of 18
(1,951 Views)
