hp66xxbc labview 7.0
Does anybody has the hp66xxbc ivi for labview 7.0?  I download the driver for labiview 7.1 and I have error.
Message 1 of 9
(4,777 Views)
If you download the LabWindows version, you should be able to create the LabVIEW driver yourself. Once it's installed, go to Tools>Instrumentation>Import CVI Instrument Driver. All of the LabVIEW IVI drivers are created from the LabWindows driver in this fashion.
Message 2 of 9
(4,771 Views)
Thanks for the tip Dennis, I never knew that nor realized that it was an option under tools.  It's the questions that driver uswink smiley.
Message 3 of 9
(4,764 Views)
Thanks Dennis.  The tip works very well.  Now I found other problem with the driver.  I tried to initialize it without using the instrument assist.  When I query the device, I have the error Primary Error: (Hex 0xBFFC0011) Identification query failed.
Elaboration: Failed to Recognize Model.
Quering the model using measurement and automation explorer, I found this:  HEWLETT-PACKARD,6612B,0,A.00.07.
Seems that the model that I have (6612B) is not supported 😞  Do you have suggestions?
Message 4 of 9
(4,746 Views)
When you run the initialize function, set the ID query to false.
Message 5 of 9
(4,744 Views)
Dennis:
Thanks. This works.  When I try to continue commanding values; I found out that the driver is using default values. This is causing that I can't command desired voltage level.
Seems that the driver is setting the model to HP6611C and allowing max voltage to 8.190.  The model that I have can handle up to 20 volts.
Do you know how to force other model in order to be able to set the voltage higher?
Thanks again for your advises.
Primary Error: (Hex 0xBFFA0010) Invalid value for parameter or property.
Secondary Error: (Hex 0xBFFC0003) Parameter 3 out of range, or error occurred while setting Parameter 3.
Elaboration: Voltage Level
Message 6 of 9
(4,739 Views)
The driver probably defaults to the 6611C if it doesn't do an ID query. I'm not sure if there is a way to disable range checking or change the model name. I tend to avoid IVI drivers and if I find a bug, I can fix it because I have a copy of LabWindows/CVI. Maybe someone else has an idea.
Do you have to use IVI or can you use the native LabVIEW driver?
Message 7 of 9
(4,734 Views)
Dennis:
I don't have preference.  Any way that make it work is welcome.
Message 8 of 9
(4,732 Views)
Then you might want to look at the other drivers available for Agilent power supplies. I couldn't find a 6612 model listed but one might be similar enough that you can modify. I haven't checked, but have you tried Agilent for a driver? You could also go http://sine.ni.com/apps/we/niid_web_display.request_driver and request that the driver be modified for your "B" model.
Message 9 of 9
(4,728 Views)
