i can send multiline interface commands but not data commands
hi
i am using a gpib controller.I cannot seem to find a way to switch between multiline commads and data commands.the key is the ATN bit as to send a DAB command the atn bit must be low. I cannot make the controller distinguish when a command is a adta command and not a multiline command,
(3,524 Views)
Please provide more information. Typically, provide the following information:
* What GPIB controller are you using?
* What programming language are you using?
* What operating system are you using?
Those are good starter questions. Typically the ATN line is asserted/unasserted automatically. If you make a call such as ibcmd to send command bytes, ATN will be asserted. If you make a chall such as ibrd, ATN will be unasserted. However, this is dependent on your driver and GPIB board. Those API calls are for NI-488.2 using an NI GPIB board. Other vendors may offer a different API to send commands and data bytes.
(3,524 Views)
sorry bit i did not know i could answer you directly.
i am using the measurement computing gpib controller cb7210.2 which is nearly ni compatabile.i am interfacing it with a microcontroller connected to the pc.Then i am trying to use a monitor program that is embedded in the microcontroller to perform remote access of instruments.i am using assembly. i have managed to communicate with the instrument.now the problem is that i cannot make the distinction between data commands and interface commands.for eg if i send 3Fh and atn happens to be 1 this is interpreted as UNL if atn is 0 then it is interpreted as data command.i need to be able to have control of the atn bit so that i can send either at will. so to problem is how to control the atn bit.
thanks
again
(3,524 Views)
I am not very familiar with the cb7210, but if it is programmed like a regular 7210, there should be an auxmr register. Within that register should be three patterns, 0x10 which is gts, and 0x10/0x11 which are tca and tcs.
gts = Go To Standby, drops attention
tca/tcs = Take Control (A)synchronously, asserts attention
I recommend reviewing the cb7210.2 manual to determine how it is supposed to be programmed.
(3,524 Views)
i found the nat7210.2 manual and it said exactly what you suggested and it makes sense.
the cb7210.2 manual is not available as far as i know and that is my difficulty.all that i am doing i have to define from the data sheet.
thanks a lot for your answer appreciate it a lot.
i will get back to you if i find out if it works or not.
(3,524 Views)
> makes sense.
The cb7210 manual is on the MC site. For some reason, they just don't
provide any links. This should have what you need.
http://www.measurementcomputing.com/cb7210/
(3,524 Views)
