i am using code"serial to disc" to read data from serial port using rs232. my file is blank. do i need a daq card or what could eb the possible reasons.
i got the code from serial port solutions in labview.. i spoke to chris from ni and he says you will need to know driver info to be able to communicate. secondly can i call you n talk to you regarding the same. tahnx for ur help richa
