ibconfig return ECAP
When I send ibconfig with option IbcReadAdjust and value 1, I get ECAP error. What is the cause of the error?
(3,263 Views)
The IbcReadAdjust option of ibconfig has been deprecated since NI-488.2 for Windows version 2.0. You must either use an old driver, or handle the byte swapping in your own code. An ECAP error is returned, indicating that the driver does not support this capability.
(3,263 Views)
