ibdev error when initialise secondary GPIB address
I have ibdev error when I use secondary address(I need use it). I use MSVS6.0 and your example, it works with keithley, but not with my device. When I work with my device by LabVIEW and for addressing use "1+1"(for example) it works. But I am getting mistake when I try to initialise device in VStudio, without secondary address it does not understand my command.
Please help me.
(4,164 Views)
The NI-488.2 API adds 96 to the secondary address to create it properly (since a SAD of 0 is different than no secondary address). Try using
ibdev 0 1 97 12 1 0
to open a device a primary address 1 and secondary address 1.
(4,164 Views)
Thank you, I solved this problem. But this information is not written in your manuals, that come with your GPIB card.
(4,164 Views)
I will look into that. I know it is documented with ibsad, but it should be documented with ibdev as well.
(4,164 Views)
