ibrsv()
Could you give an example on ibrsv(). I tried to used ibrsv() on a slave
(Non-Controller) PC to assert the SRQ, but the function can't send the SRQ
to the master (System Controller) PC as it described in the manual. Also,
after I called the ibrsv() function, it seemed not response to system very
soon. Could you explain why? My development system is VC++ 6.0 in NT 4.0
SP5. The GPIB driver is NI-488.2 v1.6. Thank you!
(6,236 Views)
Victor,
You may want to try implementing ibrsv through the ibconfig() function,
for example: ibconfig (board, IbcRsv, 64). Even though this KBase entry is
related to GPIB-ENET, you may want to check out
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/18a867925fd3ed6c8525645000512d03?OpenDocument
Rich
u!
(6,235 Views)
