ibwait rqs
I have a tnt based pci gpib card and I'm trying to get 'ibwait( dev, rqs )' to work.  The actually call is "ibwait( dev, TIMO | RQS ) and it alway returns because the call times out.  The device generates service requests and the board version, "ibwait( board, TIMO | SRQI )", works fine. When I inspect ibsta I can never find any indication that the RQS bit is ever set.
So my question is, what am I doing wrong; what am I not doing right?  I precede the ibwait with "ibconfig(  board, IbcAUTOPOLL, 1 )".  So what else am I missing?  BTW, I'm actually using linux-gpib rather than NI488.2 (can't get the NI thing to build on opensuse 11.4).
TIA,
eric
Message 1 of 8
(4,676 Views)
is there another instrument on the bus with a lower address that has asserted RQS? Polling is sequential and was originally intended to give higher priority to lower address values.
Message 2 of 8
(4,674 Views)
No, there is only the board/controller and one device (an HP3478A DMM, if memory serves).
eric
Message 3 of 8
(4,671 Views)
Eric,
Is it only the ibwait function that isn't working, or is it a communcation issue in general?
Kyle Mozdzyn
Applications Engineering
Kyle M.
Message 4 of 8
(4,664 Views)
To the extent that I've looked, it's only the specific case of ibwait on rqs (i.e. ibwait( device, RQS ) ).  Ibwait works with TIMO and SRQI flags; ibrsp, ibrd, ibwrt all work.  Just to be clear, my problem is with the linux-gpib software.
eric
Message 5 of 8
(4,662 Views)
Eric,
If its an issue with linux-gpib software, you may want to shoot their mailing list a problem to see if they can also help you here: http://sourceforge.net/mail/?group_id=42378
Kyle Mozdzyn
Kyle M.
Message 6 of 8
(4,647 Views)
First thing I did.  I'll give it another shot though.
Message 7 of 8
(4,642 Views)
Eric,
Let me know if you hear back from them. Im curious as to whats going on.
Kyle Mozdzyn
Kyle M.
Message 8 of 8
(4,636 Views)
