ieee.488 or rs232 ?
Hi everybody,
I've always used ieee.488 for communicating with instruments but now I'm facing some problems using RS232 (with VISA) even if I only need to perform simple settings and querying on an Agilent Power Supply (E364XA family). Since I come across some problem with timing, so I ask you a little help to understand some basic information about communication with instruments :
- What are the main differences between IEEE.488 and RS232...Except cost I mean 🙂
- When I'd better to use one of them instead of other?
- Are there some weaky point to care of, when using RS232 ?
Thank you all in advance...
Giovanni
(8,758 Views)
GPIB is a parallel bus,  RS-232 is serial.
GPIB can have multiple instruments on a single bus.  RS-232 is a one-to-one bus.
GPIB has a  faster transfer rate.  I'm not sure about latency.  I'll have to look that one up.
Unless cost is a major factor, I would much prefer GPIB over RS-232 for instrument control.  But for cost reasons, I'm looking to go to ethernet and LXI for future test sets.
(8,753 Views)
It doesn't talk about serial, but this is a good article to read through:Instrument Beus Performance
(8,751 Views)
+1
(8,744 Views)
