ilrd timeout error
 Hi
     I have function call from VB  Application  which i call ilrd Dev% ,Valuestr,12
Whenever i call this, below command [ usually ilwrt ] get timeout error,
tried giving sleep,timer etc options which was available in net ,Any solutions??  mathew.m@nestgroup.net
Regards
Mathew M
+91-9895519102
Message 1 of 16
(6,119 Views)
Hi
After i call this command machine takes 10-15 sec and get time out error, my next caommand call is ilwrt ..
Is there any specific settings need to done for ilrd timeout wither on machine or on vb code
Regards
Mathew M
+91-9895519102
Message 2 of 16
(6,094 Views)
Hi MathewM,
You can use iltmo to set the timeout. There is more information on this in the NI-488.2 Help, which can be found in Start > Programs > National Instruments > NI-488.2.
I hope that helps!
Rasheel
Message 3 of 16
(6,088 Views)
You might also provide some information on what the instrument is and what command you are sending. Unless you write a legitimate query, you are always going to get a timeout on a read. What happens when you test the command in MAX?
Message 4 of 16
(6,085 Views)
Hi Rasheel
                    Thanks for the repy,please see few section of my vb Call ,my machine is JDS - FITEL, with GPIB0 card ,i amnot sure whether it is hard ware setting, i have onlyproblem in reading not on writing ,its communicating with GPIB for sure
Code Below::  ---- SInce this post allows 1000 characters , only errorCeck is written
     StatusDisplay "Switch to Relative Power..."  'Displays Status on Form
    ilwrt Dev%, "*A05E" + Chr$(13) + Chr$(10), 7
     -- errorCeck
    StatusDisplay "Switch to 1.3 for IL..."
    ilwrt Dev%, "*A41E" + Chr$(13) + Chr$(10), 7
    -- errorCeck
    msg = MsgBox("Take Reference value @1310WL", vbOKCancel)
    If msg = vbOK Then
         ilwrt Dev%, "*TREF" + Chr$(13) + Chr$(10), 7
-- errorCeck
    Else
        Exit Sub
    End If
    ilwrt Dev%, "*TDO" + Chr$(13) + Chr$(10), 6
-- errorCeck
    'Comments ------> Problem STARTS After this ilrd call,see the write call comments
    ilrd Dev%, ValueStr, Len(ValueStr)                'ilrd call
   ' iltmo T10s, 13
-- errorCeck
    sReadData = Left$(ValueStr, ibcntl& - 2)
    sReadData = Right$(sReadData, 6)
    sMaxIL1310 = sReadData
    MsgBox "end reading" + sMaxIL1310
    StatusDisplay "starts Switch to 1.5 for IL..."
    'Comments ------> Here its take 10- 15 seconds and Show timout error
-- errorCeck
    ilwrt Dev%, "*A42E" + Chr$(13) + Chr$(10), 7
'-  check up to this
------ code continues---
End Sub
Thanks & Regards
Mathew M
Message 5 of 16
(6,056 Views)
Hi Dennis
 Code Snippets are posted abouve, my machine is JDSU not JGR with GPIB0 Card ,Single channel used for caliberation of cables.
Thanks & Regards
Mathew M
+91-9895519102
Message 6 of 16
(6,052 Views)
Dear All,
               Any suggesions about my queries??? help needed.
I have problem while i call ilrd function   ilrd Dev%, valustr$,Len(valuestr)
its wait for 10-15 seconds then time out error
i believe that its taking values long time for ilrd call, reading from buffer..tried trim/timeout function etc
is it hard ware of software problem?? if i give dummy ilrd call [meana again i call the same ilrd call just below the previous ilrd call] ,it getting faster for the first time ..can't identify the problem still help needed urgently
regards
mathew m - mathew.m@nestgroup.net
Message 7 of 16
(6,013 Views)
You get the read timeout after sending a *TDO command? I'm not familiar with the instrument. What does that command do? Have you run that command in MAX and gotten a response?
Message Edited by Dennis Knutson on 04-22-2008 10:19 PM
Message 8 of 16
(6,010 Views)
Hi Dennis
                  Sorry for the dealy , TDO sends data out from the device ..but its not the problem yet beacouse i put the ilrd call ont he very fast line after the first  ilwrt call result is the same , tried MAX command it s came out with no error, second time i call the ilrd the it does not have any problem ..
ilrd first call wherever in my code is the coause, after that any ilrd call will work smoothly with out timeout error
Message 9 of 16
(5,983 Views)
I did a search for JDSU - Fitel and it seems this is the maker of the instrument. You have not provided the model number. Could you do that? If you have an electronic copy of the programming manual or a link to it, that would be of enormous help.
Most instruments these days use SCPI and only after issuing a command that terminates with a '?' can you do a read. That is why it is important to review the programming manual. I suspect that you may be doing a read when the instrument has not been commanded to return any data. You cannot just place a read randomly in the program.
Message Edited by Dennis Knutson on 04-24-2008 05:44 AM
Message 10 of 16
(5,970 Views)
