ilrd vs ibrd
In looking at the functions I was not able to figure out what (if any) significant differences there are between using the ibrd() functions vs the ilrd() functions (especially for the two that have the same parameter list.)
(4,482 Views)
TonyB,
The commands are the same except that the IL- commands are exclusive to the BASIC languages. The modern commands are all IB- based and are the preferred programing practice for all modern programs. The only reason to use the IL- commands is if you were programming in an old BASIC environment that did not recognize the IB- commands.
-Marshall R
(4,463 Views)
OK, Thanks for the quick response!
Just to make sure I understand correctly.
The ib commands are the newer standard and the il commands are for legacy support?
In Visual Basic 2008 I have access to both so I should use the ib commands.
(4,458 Views)
Yes, you should use IB- it became the standard for Visual BASIC when Microsoft released Windows 95.
-Marshall R
(4,440 Views)
