install visa in Fedora23 Error( updateNIDriver )
I have installed the VISA15.5 for linux. Still could not control the serial. So I need to updateNIDrivers.
The output of "uname -r" is 4.2.3-300.fc23.x86_64.
I wondered  that the file In /usr/src/kernels is 4.5.7-202.fc23.x86_64 and  file in /lib/modules is 4.2.3-300.fc23.x86_64, they are different.
When I type updateNIDrivers 4.2.3-300.fc23.x86_64, the output is:
<11>Jul 13 10:50:11 nikal: ERROR: Error locating kernel sources for the requested kernel version (4.2.3-300.fc23.x86_64).
usage: /usr/local/bin/updateNIDrivers [--no-prompt] [kernelVersion]
When I typed updateNIDrivers 4.5.7-202.fc23.x86_64 , the output is:
<11>Jul 13 10:51:02 nikal: ERROR: /lib/modules/4.5.7-202.fc23.x86_64 directory not found.
<11>Jul 13 10:51:02 nikal: ERROR: Error locating kernel sources for the requested kernel version (4.5.7-202.fc23.x86_64).
I am not good at linux, could someone tell me how to solve the problem.
Any suggestion would be good.
Thank you.
Li
(3,984 Views)
not an expert, but my similar problem was that NI-VISA is a 32-bit package.  Your Fedora installation must support 32-bit applications.  If you try to run it without the compatability libraries you will get errors that make no sense.  I suspect that update is looking for VISA compiled for your 64-bit kernel, which does not exist.  Google "fedora 32 bit" and you will find plenty of help.
(3,976 Views)
Thank You for your answer.
Could you say it more clearly. I do not understand it well?
I seem to be installed the 64 bit package. And the system was 64 bit.
Thank you
(3,967 Views)
I may have spoken too soon.  I see now that VISA runs on 64-bit systems, but can support only 32-bit applications.  I misunderstood what NI was saying about the limitations of VISA, all they say is: "Currently, only 32-bit applications are supported on the x86-64 architecture.".  I think that means that whatever you are using to access VISA needs to be a 32-bit app.  I hope somebody else can verify that.   What are you using?
My answer may have been incorrect.  I don't have another answer for you, sorry.
(3,959 Views)
I think I understood you already.
I would try it later,
Thank you for your answer.
(3,955 Views)
