installing visa 5.1.1
Hi all
I'm running LabVIEW 8.5 on my win machine, with visa 4.2. I downloaded 5.1.1, however when uninstalling the old version through control panel it indicates this will also remove NI Instrument I/O assistant. Can this be recovered after installing the new drivers?
Also, should I also update visa runtime (4.2) as well? Thanks
(3,393 Views)
NI-VISA 5.1.1 bundles NI Instrument I/O Assistant 2.7.0. And each LabVIEW version's support is ENABLED as default, if the one is already installed.
(3,386 Views)
