instrument driver hp34970A advanced scan example timeout error
if i scan more than two channels using the hp34970A andvanced scan example.vi instrument driver, i get"timeout expired before operation completed occured at visa read in standard event status.vi of advanced scan example.vi. this occurs before the instrument finishes the scan. i am using mac osx. any suggestions? thanks
(3,590 Views)
I do not have experience with this instrument or driver but have you tried increasing the timeout value? On the front panel of the VI that you mentioned there is a place for the timeout value.
Please repost if you still have problems with it. Thanks!
JenK
(3,583 Views)
Problem solved! The timeout value within the initialize.vi of the driver was set to the default 10 seconds. I increased that and now everything works fine. thanks.
(3,578 Views)
