invoke hp605x_32.dll error---- parameter 2 is invaild
hi All,
      i have downloaded the vixpnp driver for hp6050(electronic load) from ni driver network.But have a strange thing.
      i wrote the code with c#,and create the .cs file for hp6050 with ni measurement studio.
     "hp605x DCLOAD = new hp605x("GPIB0::8::INSTR", true, true);"
when i execute the load self_test,the instrument work fine.
    int result;
            StringBuilder test_message = new StringBuilder();
           int a=DCLOAD.self_test(out result, test_message);
           if (a==0)
               MessageBox.Show("ok");
and set_channel is same
but when i execute the function for measure the current of the load,there is a error message ("parameter 2 is invaild")
int measurement_type=0;
            double measurement=0.0;
            DCLOAD.setChannel(2);
            DCLOAD.measure(measurement_type,out measurement);
                MessageBox.Show(measurement.ToString());
what is wrong?everyone,Can you give any advice for it?
thanks a lot.
(3,190 Views)
no respond?
(3,173 Views)
