11-30-2002 06:44 AM
12-02-2002
12:25 PM
- last edited on
05-27-2025
09:43 AM
by
Content Cleaner
If you are using the Legacy serial VIs, you should really switch to the VISA VIs. Also make sure you are opening a session to each of the com ports at the beginning of the program and closing each at the end of the program. Problems can arise if your try to open a session to a port that already has a session open. Also you should update LabVIEW to 6.0.2
If you are still having problems post the error code and error message you are getting.
Ray K
NI Applications Engineer
