issue connecting to both a network device and a remote system device
I currently use LabVIEW 2016 to connect to an FPGA/PXI chassis. In NI-MAX it is listed under "remote systems." I have one vi which programs the FPGA, and then a host program which calls that using an "Open FPGA VI Reference." I would like to have that host program also control a second instrument (for testing purposes, I am using a tektronix AFG3022 function generator with its NI drivers). In NI-MAX, this test instrument is under "My System -> Network Devices." I first modified one of the example vi that came with the tektronix driver and verified that I could control just the tektronix with LabVIEW. When I tried to incorporate this code into my larger host program, however, I could not connect to the tektronix anymore [Error-1073807343, VISA Open in Tektronix AFG 3000 Series.lvlib:Initialize.vi->TESTethernet_Host_KappaG2.vi]. In fact, when I went to the drop-down menu I had previously used to select the Tektronix VISA resource name, it was no longer an option (the options now include PXI resource names). Any idea why this might be happening?
(2,522 Views)
Accepted by topic author SSoren
So, I'm still not sure why what I did before didn't work, but I have now made it work. I deleted the tektronix in NI-MAX from the Network Devices in "My System" and re-registered it as a Network Device for the PXI chassis in "Remote Systems." I am now able to control both with the same host program.
(2,361 Views)
