Hello!
I am having some troubles with Keilthley 236 source-measure unit (over GPIB) as it falls into LSN (listener state). I have tried to use the command "ULN" or "IFC", but once the system falls into LSN state, there is no way out and I would have to restart the instrument again. What is worse is that this takes place on a random basis.
Basically, I have open, write, read, close visa sequences and most of time it works fine. The problem is that the system falls into this dark state without any warnning. Do you have any solutions for this?
Also, I have noticed that whenever I was using the Keithley source-mesaure unit, another instrument, spectrum analyzer Agilent 35670A (also over GPIB) seems to have troubles and it also falls in to a "dark" state where it simply sits and wait for the Labview to receive service request (wait for RQS) from the instrument. I noticed that this occurs whenever I use the two instruments together over GPIB (of course with the different addresses). First few runs works fine, but after awhile either Keithley falls into listener state or the spectrum analyzer falls in to wait state.
