keithley 2401
hi all, do anyone have Keithley 2401 SMU LV drivers to read Voltage vs time and current vs time.It is not there in either labview instrument drivers or keithey webpage.
Thanks in advance..
(2,637 Views)
Hi
How fast or slow do you need to measure?
greetings from the Netherlands
(2,626 Views)
Thank you for your reply..As of now i dont know the rate of readings to measure and there will option to give time stamp.If i have that VI i can use accordingly to my use.
(2,616 Views)
I posted the general idea for measuring V or I vs time with a Keithley SMU here - https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Keithley-2450-Continuous-current-measurement...
This example is for the Keithley 2450, but you use it to learn what you need to do to build your own version for the Keithley 2401.  The 2401 driver will have all the same functions you can use to build the same codes suitable for your needs.
Hope that helps.
Craig
(2,591 Views)
