keithley 487 autorange problem
Hi
I'm using keithley 487 pico ammeter voltage source in laboratory.
When I measure current in autorange, I can't get a good measurement.
When the data goes to smaller range (nano ampere), when the scale change nanoscale
Measurement jump down and a sharp drop was seen in the Graf.
(4,569 Views)
@ömer wrote:
Hi
Different ranges use different setups to measure.  In the case of current, it would be a different sense resistor.  That could easily account for a rapid change in current.
In general, it is a good idea to just keep with a single range when doing sweeps like this.
(4,565 Views)
