keithley 6221 driver - labview upgrade 2009 to 2012
Hi
I'm using Labview drivers, provided by Keithley, to control a Keithley 6221 power supply. They provide versions for LV 8 and 2009, and I currently use 2009. However I'm going to have to upgrade to LV 2012. Will the 2009-compatible drivers be ok with LV 2012 ? What should I look out for ?
As you have to login to Keithley's website to download the drivers, I've attached them.
Message 1 of 8
(9,134 Views)
Accepted by topic author scalpas
The drivers are using VISA, so I wouldn't expect any issues upgrading to 2012.  The thing I did notice is that the files are set to Read Only.  Disable that via Windows Explorer so you can mass compile the VIs before using them.
Message 2 of 8
(9,130 Views)
Thanks for the answer crossrulz.
Regarding your comment about compilation, this may be a stupid question, but how and why should I compile the VIs ? I usually just hit the run arrow to run a program.
Message 3 of 8
(9,110 Views)
You want them compiled (and saved) to the new version.  They will open a lot faster that way.
Message 4 of 8
(9,105 Views)
How is via Tools/Advanced/Mass compile
greetings from the Netherlands
Message 5 of 8
(9,096 Views)
So compiling in this case would just be taking the Labview 2009 VIs and saving them in Labview 2012 format ?
Message 6 of 8
(9,084 Views)
Yes
Normally a LabVIEW diagram is compiled during editing. In fact a broken wire is the LabVIEW equivalent of a syntax error warning.
But mass compiling is handy when upgrading.
If you don't mass compile it will also work but ech time you load a new vi then it will be compiled while loading.
Message 7 of 8
(9,078 Views)
Ok thanks !
Message 8 of 8
(9,072 Views)
