kjnml
So, if i want to have a knob to control V/div a how can i manage it; through vertical range and probe attenuation ;can you give me an example;and something else
also the driver give  in configure channel characteristic a vernier(true/false)  may be to set this controle  i didn't understand this
 thanks for the help!I am honestly gratefull.
(4,813 Views)
If you are using an instrument driver, simply right click on the subVI input and select Create Control to duplicate what is on the front panel of the subVI. Otherwise use a knob with text labels.
(4,808 Views)
 the problem when i was measured 30mv and the probe attenuation is 10(vertical range 10) but my program run when i set the probe attenuation to 25
thank you
(4,788 Views)
 the problemis the program was blocked  when i was measured 30mv and the probe attenuation is 10(vertical range 10) and  my program run when i set the probe attenuation to 25
thank you
(4,787 Views)
I don't understand your last two posts. Is there an actual question in them?
(4,785 Views)
