labtop and desktop
I use GPIB USB HS controller.  When I connect it to my labtop an run MAX I can see the keithley connected to the controller, but when I connect the same controller with the same instrument on the desltop, which have the same labviwe, I can not see keithley. Capture of both cases are attached.
Another question, when I use labviwe code what I should write in the GPIB adress string?? Is it only the primary adersss 22 or the ID, which is zer in my case, should be included also.
Message 1 of 11
(6,655 Views)
On the pc, what happens when you right click and select Scan for Instruments? What versions of NI-488.2 and NI-VISA do you have installed? What is your os?
The instrument must be listed in MAX before you can use LabVIEW. You would then use the VISA Resource Name - i.e. GPIB0;:22::INSTR or whatever alias you might assign to it.
Message 2 of 11
(6,647 Views)
On the desktop, where i have the problem,  I have 3.1.2 NI 488.2 an NI VISA 5.4. on the labtop I have NI 488.2 version 2.81 and NI visa 5.1. .Where should I right click
Message 3 of 11
(6,616 Views)
The same place you did on the laptop - on the controller listed in MAX.
Message 4 of 11
(6,607 Views)
I attached a photo for the MAX main page and when I right click. also a list of the softwears.
Thanks alot
Message 5 of 11
(6,569 Views)
Thanks alot
Message 6 of 11
(6,569 Views)
When you right click on the controller, you should have an option that says Scan for Instruments.
Message 7 of 11
(6,560 Views)
I see what you mean. This option is not avialable on the desktop. I can see it on my labtop.
Message 8 of 11
(6,555 Views)
Are you logged on as administrator?
Message 9 of 11
(6,542 Views)
yep
Message 10 of 11
(6,534 Views)
