labview---connector pane
anyone knows what is connector pane and how to set up the connector pane?
(4,841 Views)
Please read this document and post again if you need further help.
(4,831 Views)
we're trying to measure IV and LJ of our project and the below error description is detect at the collector of the circuit.
Error -89130 occurred at DAQmx Start Task.vi
Possible reason(s):
Device not available for routing.  It is possible that the device needs to be reset or that the device is being reset.
If you are resetting the device, wait for the reset to complete.
For example, if you have used the device through Traditional NI-DAQ, you must reset the device before the requested route can be made.  For SCXI devices, you must reset the communicator DAQ device. Call the Traditional NI-DAQ Device Reset VI or the Init_DA_Brds function. To reset all devices in Traditional NI-DAQ, right-click the Traditional NI-DAQ Devices folder in MAX and select Reset Driver for Traditional NI-DAQ.
Task Name: _unnamedTask<0>
(4,788 Views)
the Stig,
I was wondering if you could give some more information about your setup. What DAQ card are you using and what version of DAQmx are you using? Here is an article which has some troubleshooting steps for this particular error.
In the future, a more appropriate place for this post would be the Multifunction DAQ board. Let me know if this helps.
Kent
(4,754 Views)
