labview linux centos 8 - visaconf problem (miss libPythonInterface.so) and visa
I installed visa driver with el8 package el8 for centos 8. (yum install ni-visa )
I call visa in my labview program, and i can't find the card i must drive.
Utility visaconf send error message at launch, and when refreshing peripherics:
Can't find library libniPythonInterface.so.
Make sure this library is installed in LD_LIBRARY_PATH
Any solution?
 libniPythonInterface.so Library is missing from all of my directories.
(1,548 Views)
What kind of card you are using?
__________________________________________
The best way to thank, is to give KUDOS
(1,481 Views)
