labview the Sampling rate of Agilent 6000 scope
how to use Command to get  the Sampling rate of Agilent 6000 scope?
(4,082 Views)
Go to Help> Find Instrument Drivers.
(4,078 Views)
i have installed the drivers ,but it has only to read the oscilloscope command ,and  just  display what is on oscilloscope, but can not change its parameters remotely,for instance ,how to change the Sampling rate remotely?
(4,072 Views)
I don't know the specific model since have not provided it but look on the instrument driver palette. Typically, there will be dozens of functions. In any case, all of the commands will be listed in the manual.
(4,067 Views)
thanks! i will try .
(4,065 Views)
i use this to get sample rate ,but i want to change sample rate by labview,how should i do ?
(4,059 Views)
