labview with enet-232
I am using LabVIEW 7.1 on a SUN running Solaris 10 to command RS232 instruments. We have two RS232 instruments connected to a ENET-232/2 with the SUN and ENET on an isolated network and connected through a switch. I have run visaconf to find and set up the ENET-232 and I see the two visa reference ids as ASRL0::ipaddress::port#::INSTR. When I run a simple command and read vi, I see the RX and TX lights flashing and the Port no. light come on the ENET-232. A successful command received by the instrument will cause the instrument to send back a > (greater than), However, I receive a timeout error (-1073807339) for the VISA Read and no evidence that the instrument has changed configuration or gone into remote mode.
Any ideas?
(3,032 Views)
See whether this or this is helpful
(3,013 Views)
