libnipalu.so failed to initialize
centos 7 64bit, first, use ./INSTALL to install lv2017pro-linux, then use ./INSTALL to install NI-VISA-17.0.0 , when run visa function in labview , tips " libnipalu.so failed to initialize Perhaps you need to run updateNIDrivers Aborted (core dumped) " , the labview auto quit . what should i do to correct this ?
Message 1 of 1
(1,573 Views)
