lms 200
i have installed the plug and play driver for the sick lms2XX but when i run it, always it gives me the same Error i tried alot to solve those problems but i couldn't, i tried even to build my customized vi but the same problems occurred, i attached the Error list in a a word doc bellow. please help!
(5,101 Views)
Where did you get the driver from? Can you attach an image of the broken VI's block diagram and of the subVI it is calling? How did you rewire the subVI?
(5,092 Views)
hello,
i have used the NI IDF to install the driver, so normally it is a certified driver, here is the broken VI's and i don't know how to rewire them.
thank you.
(5,073 Views)
It says that the VISA Configure Serial Port is the problem. Did you happen to edit it by accident?
(5,067 Views)
thank you it seems at the end i came to the same result as you said so i reinstall labview and the problem is gone. and my lms is warking perfectly.
(5,061 Views)
