lockup during POST
Can you help me ?
My customer has a Dell Optplex GX240 with 128mb and processor P4 1.7ghz. The motherboard has a chipset Intell 845. After to install a PCI GPIB Card NI 488.2, the system lockup during POST and appears follow message "i/o card parity interrupt at f000:db47".
We have tested in all slots, but the problem persist.
How can we solve that problem ?
Thanks in advanced.
Message 1 of 12
(4,702 Views)
Sounds like the board is bad.
Have you done anything to prove otherwise?
Ben
Message 2 of 12
(4,702 Views)
Ben,
Another cards as modem, sound card, video card works fine on all slots. The problem happens only with that card GPIB.
Marcelo
Message 3 of 12
(4,702 Views)
Hello-
Try updating the BIOS for that machine. Also, try the card in another machine. If the card fails in a second machine, there likely something wrong with the board. The RMA process is best done through the phone at 512-795-8248.
Randy Solomonson
Application Engineer
Message 4 of 12
(4,702 Views)
The Bios has updated, version A03. The card has tested in another system, Dell Optiplex GX110 PIII 866, 64mb ram. The problem following card.
Message 5 of 12
(4,702 Views)
We have a number of PCI-GPIB cards in Dell GX110's. They all work fine. If the problem follows the card, then there is something wrong with the card. Phone the number that was given above and get the card replaced. NI is usually pretty good about that kind of thing.
Rob
Message 9 of 12
(4,702 Views)
Ok, thank you for explain your experience. I'll try replace that card with manufacturer.
Message 11 of 12
(4,550 Views)
It still sound like the board is defective.
Ben
Message 6 of 12
(4,702 Views)
Ben,
Then we have many machines, where your card dont works fine and only this card dont works fine. Another cards as modem, nic, video card and sound card work fine. You're warranting that card can't to fail. Is that ?
Message 7 of 12
(4,702 Views)
Hello-
We've had similar problems in the past with certain machines. Search ni.com for +gpib +hang. The solution has generally been to upgrade the BIOS. Try upgrading the BIOS. If the current update of the BIOS does not help, please write back. Also, include BIOS version number, please.
Randy Solomonson
Message 8 of 12
(4,702 Views)
