microcontroller USB labview
Hi everyone I want to display the data from microcontroller on Pc by using labview I use USB port to transmit these data for labview. I dont know how I display 4 data in one interface I installed VISA USB.  There are anyone to help me to do this interface and thank you in advanced.
ther are 2 file :
- the microcontroller program
- how USB send data every 100ms, each data is advanced by hexadecimal code (1,   ,2,    ,3,     ,4,     ,)
(5,546 Views)
What type of USB cable are you using? You can always look at the examples by going to help at the LabVIEW splash window>>find examples>>hardware input and output. There are alot of examples here that you can start with such as VISA folder. By VISA USB, do you mean NI-VISA? becuase you do need this driver.
You can also look at our community examples here http://zone.ni.com/dzhp/app/main by searching in browse. Also take a look at this example: https://decibel.ni.com/content/docs/DOC-19723
(5,523 Views)
(5,341 Views)
You can labview communicate with the microcontroller through the USB port
http://www.microchip.com/forums/m659974.aspx
(5,335 Views)
