mitutoyo
I don´t have experience doing driver for instruments. I am trying to build the driver of a Mitutoyo Laser micrometer using the serial port of the computer. The model of the laser micrometer is MITUTOYO LSM 500 S. The user´s manual is this:
http://www.mitutoyo.com/manuals/99mbc094a_lsm-500s_516s.pdf
And the display unit:
http://www.mitutoyo.com/Manuals/99MBC095ALSM6200.pdf
I have attached the VI that I have done..it´s run without errors..but I cannot read data.
Thank you very much for your help!!
Best regards
(3,811 Views)
You have a duplicate post about this same topic at http://forums.ni.com/t5/LabVIEW/laser-micormeter-mitutoyo/td-p/2038020
where you were told to learn more LabVIEW and specifically look at the examples that ship with LabVIEW.
Don't keep spamming these forums with the same question.
(3,809 Views)
thanks, I tought I have posted in the wrong place before. I read what suggested. I tried with Max and and error messagge VISA:  (Hex 0xBFFF0015) Timeout expired before operation completed. was given.
I download hyperterminal for windows 7, but it doesn´t recognize the port. I think I have a problem with the pin connections..
I will check this now
(3,803 Views)
