modbus
Hello!
I am a beginner in Labview and I need to write a program, so please help. I am using two temperature controllers set temperature using the MODBUS protocol. I do not know how (after comparing the set and actual temperature) have the command "heat" . All I know is that the registry 25 I save the value 2 with Preset Single Register command. In Annex Vi. Thanks in advance for any advice.
(4,763 Views)
Somehow it worked 😉  I think it is about closed.
(4,593 Views)
