modem omron
I´ve connected an cpm1a omron plc to pc via lookot protocol driver 4.0 with server explorer with opc lookout protocol and Ok. But I´ve a problem when connect via modem (GSM). The lookout protocol driver give alarm "remote respone incorrect". The connection with remote modem is Ok because with syswin i haven´t problem.
(3,572 Views)
The first thing you should check is whether Lookout Protocol Driver has configured the COM port for remote connections. Select Options>>Serial Ports in Lookout. Select Dial-Up for a modem connection or Radio for a radio modem connection then click Accept.
If that doesn't solve the problem, please contact NI Technical support at www.ni.com/ask and select "E-mail NI" as a communication method so we can help you troubleshooting this issue.
Cyril Bouton
Nationla Instruments
Cyril Bouton
Active LabVIEW Developper
(3,572 Views)
